Measuring 4-20mA current loop without common ground.
haxan7
I am powering my microcontroller and a device that outputs 4-20mA current from the same power supply, so I need a circuit or an IC that can measure 4-20mA loop without a common ground, because they will already have a common ground.
Add a small resistor in series with the loop and measure the voltage across the resistor with a Difference Amp or an Instrumentation (differential) Amp.
I do not see any problem with common ground. The current signal is only dependent on measured quantity and does not get affected by ground loops.
