Rtk89
Newbie level 6
- Joined
- Nov 15, 2013
- Messages
- 12
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 85
Dear everybody,
I am trying to write an easy code to PIC12F615, but it is not working.
I would like low level in GP0 pin when the frequency is under 5Hz or no signal in GP2 pin, but the output (GP0) has unstable state.
The PIC is working with 4MHz quartz.
Thank you very much for help.
unsigned int t=0;
int cnt=0;
void interrupt() {
if(CCP1IF_bit == 1) { // Rising edge
CCP1IF_bit = 0; //reset capture interrupt flag
cnt++;
if(cnt == 1) // first rising edge is detected
TMR1ON_bit = 1; //timer1 start counting
if(cnt == 2) //second rising edge is detected
TMR1ON_bit = 0; //stop timer1
t = (CCPR1H<<8) + CCPR1L; // Store the current value of Timer1
CCPR1L=0; //Reset timer
CCPR1H=0;
PIE1.CCP1IE = 0;
PIR1.CCP1IF = 0; //reset capture interrupt flag
PIE1.CCP1IE = 1;
cnt=0; //reset rising edge counter
if(TMR1IF_bit == 1){ // TMR1 Overflow
CCPR1H=0;
TMR1IF_bit = 0; //Reset TMR1 Overflow bit
cnt=0; //Reset riding edge counter
t = 0;
void Configure_Capture(){
//1:8 Prescaler, External CLK
T1CKPS1_bit = 1;
T1CKPS0_bit = 1;
//Capture every rising edge
CCP1M3_bit = 0;
CCP1M2_bit = 1;
CCP1M1_bit = 0;
CCP1M0_bit = 1;
CCP1IE_bit = 1; // Enable CCP1 interrupt
//enable all interrupts
PEIE_bit = 1;
GIE_bit = 1;
TRISIO = 001100; //GP0, GP1 ,GP4 ,GP5 are outputs , GP2, GP3 are inputs
//reset high & low bytes of timer1 & capture registers
TMR1H = 0; TMR1L = 0;
CCPR1H = 0; CCPR1L = 0;
TMR1ON_bit = 0;
void main() {
GPIO = 0;
ANSEL = 0; // All pin digital
ADCON0 = 0x00; // Disable ADC
CMCON0=0;
CMCON1=0; // Disable comparators
Configure_Capture();
do{
if(t <= 50000 && t > 0){
GPIO = 000001;
} else GPIO = 000000;
} while(1);
