.meas command issue for Hspice 2017
cheweiwu
Newbie level 2
Taiwan
Hspice 2017 .meas command issue
Dear All,
there's a .meas command problem i met for different version of Hspice.
if there are 3 delay time obtained by .meas command
for example:
tr1 = 1e6
tr2 = 2e6
tr3 = failed
and i use MAX option to find the largest one:
.meas tran trise param="max(tr1,tr2,tr3)"
if version of spice = 2014
trise = 2e6
if version of spice = 2017
trise = failed
i tried MEASFAIL option, which would not help because the option
just replace "failed" to 0 in .mt# and not involve the calculation of MAX option.
Does anyone know how to execute MAX option with failed parameter in 2017 Hspice?
Thanks a lot ...
Re: Hspice 2017 .meas command issue
Try performing the base .measures first, with error
trapping and substitution of a benign real number
for any "failed". Then do the max() knowing that a
sane value exists for all, beforehand.
Seems like there might have been a built-in default
assigned to "failed" (NaN, in other simulators?) that
got changed across the major release boundary.
HSpice vendor applications engineering would likely
be a better resource for you, than random volunteers
from Teh InterWebz.
