learning_curve
Member level 1
Can anybody help me understand what "metal option"
or a "metal only change" means with regard to analog/digital layout?
Note: This feature currently requires accessing the site using the built-in Safari browser.
Right. In this context, a "metal-only change" may mean an (as an option) anticipated, relatively simple change of the top-most metal pattern - which - in its simplest form - may be accomplished by a laser cut through the passivation layer and the top-most metal in order to interrupt a metal wire connection. It's also possible to connect 2 adjacent top-metal structures by an ion beam fill-up operation.... when a modification needs to be made to a design a "metal-only change" means that the modification will result in only changing the upper metal layers and not changing the base layers such as nwell and substrate.
However, could someone else answer a further question?! Why would it matter if the person changed the base layers for a lower level macro block if it is NOT used repeatedly in the design and it does NOT change the location of the pins and would not affect the LEF DEF or whatever it's called messing up the integration teams auto-router?
