Mcp1541 4.096v reference ic
jit_singh_tara
Full Member level 6
Delhi , India
I want a stable reference voltage source for 12bit adc conversion .
For that purpose i opted for mcp1541 from microchip .But there is difference in the o/p for every part .
1st IC :4.098V Dc.
2nd Ic : 4.110V DC.
3rd Ic : 4.084 V DC.
Can somebody explain why this kind of response is there .
Is there some ic with only +-1mV variation in voltage reference of 4.096V .
hello,
Initial accuracy +-1% maxi
and 50ppm /°C
see datasheet
your 3 device are inside the spec. DS21653B page 2 !
min= 4,055
max=4.137
Ok i got the point with mcp1541 , But is there any other option using which i can generate a stable 4.096V which doesnt change with time . I dont want to use trimpot with supply......
i can generate a stable 4.096V which doesnt change with time ...
No chance to get better with a low cost voltage reference..
you allways will have some change with ambiant temperature and during time
+-50ppm /°C + and maxima +-4mV f(time)
so the best way is to use a calibration value in EEPROM to reduce calculus error in physical unit conversions.
because even the absolute reference is 4110 instead of 4096 => delta 14mV , next change along temperature or time will be less..
and so use 4110 in your application..
B.W. What is the purpose of these Volt reference ?
for 12bits ADC ?
all the measure chain must have similar accuracy level..
Certainly, however the most appropriate choice depends on several other key specifications, besides the initial accuracy:
1. Drift/Temperature Coefficient
2. Maximum Output Noise
3. Quiescent Current
4. Dropout Voltage
5. Shutdown Capabilities
6. Current Source/Sink Capabilities
7. Cost/Budget Restraints
With a voltage variation of +/- 1mV @ 4.096V output, look for a device with an initial accuracy of 0.04% or better.
Some possible options are:
Example, ADR4540B or ADR444B
Linear Technology - Voltage References
Example, LT1461A, LTC6655B
BigDog
