MCP 2515 (CAN controller)
torana
Member level 2
Member level 2
dear friend,
i am using MCP2515. i am little confuse. In MCP2515 PDF
register name is
TXBnDLC and the address of same register is 35H,45H,55h, then which one is the address.
CAN controller you are using having three transmit buffer and each data link control for each transmit buffer as
transmit buffer 1 - 35h
transmit buffer 2 - 45h
transmit buffer 3 - 55h
likewise.
register name is
If you examine, a bit more carefully, the name of the register, TXBnDLC, you will notice the lower case n which indicates in this case the register name is simply a generic, while TXB0DLC, TXB1DLC and TXB2DLC are specific register names corresponding to addresses 35H,45H and 55h respectively.
Reference: MCP2515 Datasheet, Section:11.0 REGISTER MAP, Table: 11-1, Page: 63
Are you attempting to write a custom driver for MCP2515 and a non-PIC microcontroller? If so, what specific microcontroller?
BigDog
thank you ...
actually i am using at89s8252(it is having SPI). writing code in assemblly language
