Hi, I like the simplicity of the mc1374 analogue tv modulator which can operate in the low vhf band only (100MHz max).
By luck, I found that they have produced also the mc13074 (notice the zero), still tin DIP package that can operate up to 500MHz i.e. the vhf 2 and the beginning of the UHF band.
It's datasheet states that it has some improved features other than the frequency range expansion.
I would like to use the mc13074 to build an "all band" simple tv modulator (I guess it can operate without problem on the low vhf band, since it operates on uhf ok).
However, I cannot find any sources to buy it.
Can you please help me a bit with this?
