ammaralwazzan
Newbie level 6
hi
i am working on MC-CDMA channel estimation
cdma + OFDM(802.11a)
i try two types of channel estimation : Block type and Comb type
i am using MATLAB built in function (rayleighchan) more specificlly (stdchan) as follow:
bitrate = 20000000; % Bit Rate
ts = 1/bitrate; % ts is the sample time of the input signal, in seconds (bit rate is 10Mbps)
fd = 0.0001 ; % fd is the maximum Doppler shift, in Hertz
H = stdchan(ts, fd, 'itur3GPAx'); % Creat Channel
H.ResetBeforeFiltering = 0; % Continous Rayleigh Channel
H.StoreHistory = 1; % Plot Channel parameters
H.NormalizePathGains = 1;
the result gave me better performance for Comb type more than Block type:
my information said that Block type suitable for frequency selective fading while Comb type is suitable for Flat fading channel
and you can see that i insert the doppler frequency near to zero which is mean that the channel is very slow fading
so if i try to classify my channel i think it will be (flat or frequency selective) slow fading which is mean that Block type should have better performance than Comb
final note that i used a 16 pilot insertion for comb type , while in Block type i sent [complete OFDM Pilotsymbol then (6 DATA OFDM SYMBOL)]
so is the result correct and why?
please answer me as soon as possible
Best Regards
Best Regards
