Maximum voltage on PCI adjacent pins on PCB
yans123
Junior Member level 2
Israel
Hello,
I would like to plan a test PCB with multiple components that will interface to automatic tester with PCI edge connector.
Since I would like to conduct test of up to 300VDC, I want to know what is the maximum voltage allowed between 2 adjacent PCI edge connector on PCB?
How is it dependent on temperature?
THanks, yans.
just a thought,
1/10 track pitch =(1000V brake down in air).
so if you got 300V 1/20, would be ok, but i would use 1/10 pitch or even 2/10. ie. leave redundant pins between rails
