Munib
I have been using 8051 mcu with crystal of 12MHz.Now i am going to use PIC18F452.The maximum crystal frequency given in datasheet is 40MHz
My question is what is the effect of using higher operating frequency i mean if there are some special considerations while writing code or it is just as normal.
is there any special external circuitry considerations for using higher operating frequency?
I have to interface this mcu with a RF module with center frequency 418MHz.
Also when using 8051 it is more convenient to use 11.059MHz rather than 12 MHz
because with 11.059MHz it is easier to find an integer value to be loaded in TH1 for generation of baudrate.It is very convenient without disturbing the operating speed much.
Is there such case for PIC18F452? If yes then please specify that crystal frequency.
I personally think that as most of the instructions of PIC take 4 clock cycles thus if i will choose Crystal whose frequency is some multiple of 4 then timing calculations will be straight forward.
And if some one has used PIC18F452 tell me the part number for the crystal used
