PsySc0rpi0n
- Joined
- Oct 5, 2014
- Messages
- 5
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 43
Hello everyone...
I'm new here and I need some help.
I'm studying Electronics Engineering and we are working with an 8051 compatible MCU which is DS89C450 from Maxim.
The problem I'm facing is that my MCU accepts any ASM code but can't make it work with any C code.
I'm using MCU8051IDE with SDCC behind it to compile my codes.
Here is an example of ASM code working:
And here is some non working C code:
So this moment I only have 8 LEDs connected to Port P1 and 3 more connected to P3.5, P3.6 and P3.7 just to check if everything was ok.
But with C code I can't do anything. LEDs just doesn't respond to any C code!
Any help is appreciated.
Thanks
Psy
main:
MOV P1,#00h
CLR P3.5
CLR P3.6
CLR P3.7
ACALL delay
CPL P3.5
ACALL delay
CPL P3.6
ACALL delay
CPL P3.7
ACALL delay
MOV A,P1
CPL A
MOV P1,A
ACALL delay
SJMP main
delay:
loopcon:MOV R5,#0Ah
loopext:MOV R7,#0B4h
loopint:MOV R6,#0FFh
DJNZ R6,$
DJNZ R7,loopint
DJNZ R5,loopext
RET
END
#include "reg_uC89C4xx.h"
void delay_msec (unsigned int msec) {
while (msec--){
TMOD = 0x01;
TH0 = 0xFD;
TL0 = 0x4B;
TF0 = 0x00;
TR0 = 0x01;
while (!TF0);
TF0 = 0x00;
TR0 = 0x00;
void main (void) {
while (0x01){
P1 = 0xFF;
delay_msec (0x01F4);
P1 = 0x00;
Thanks
Psy
