sayonee
Newbie level 6
Hello there I am trying to implement SPI protocol.I am interfacing 7 segment circuit ( 4 units ) using MAX 7219 and I am not able to get the desired LED output ...please let me know where I am going wrong ...
Thanks
Thanks
#include<reg51.h>
#define uchar unsigned char
#define uint unsigned int
#define HIGH 1
#define LOW 0
#define TRUE 1
#define FALSE 0
#define ZERO 0
#define MSB 0x80
#define LSB 0x01
//max7219 part
#define DECODE_MODE 0x09
#define INTENSITY 0x0A
#define SCAN_LIMIT 0x0B
#define SHUT_DOWN 0x0C
#define DISPLAY_TEST 0x0F
//pin defined
//change this part at different board
sbit LOAD=P1^2; //MAX7219 Load-Data Input: rising edge pin 12
sbit DIN=P1^1; //MAX7219 Serial-Data Input: rising edge pin 1
sbit CLK=P1^0; //MAX7219 Serial-Clock Input: maximum 10MHz pin 13
void Write_Max7219_byte(unsigned char temp);//write max7219 a byte
void Write_Max7219(unsigned char address,unsigned char dat);//write max7219 command and data
void Init_Max7219(void);//Initize max7219
void delay1ms(uint x);
void main(void)
uchar i,j=1;
Init_Max7219();
/*for(i=1;i<=4;i++)
Write_Max7219(i,0); */
for(i=0;i<=3;i++)
Write_Max7219(i,0);
while(TRUE)
for(i=1;i<9;i++)
Write_Max7219(j,i);
delay1ms(1000);
j++;
if(j==5)
j=1;
for(i=1;i<=4;i++)
Write_Max7219(i,0);
void Write_Max7219_byte(uchar temp)
unsigned char i;
for (i=0;i<8;i++)
CLK=LOW;
DIN=(bit)(temp&MSB);
temp<<=1;
CLK=HIGH;
void Write_Max7219(uchar address,uchar dat)
LOAD=LOW;
Write_Max7219_byte(address);
Write_Max7219_byte(dat);
LOAD=HIGH;
Write_Max7219(SHUT_DOWN, 0x01); //Normal Operation XXXXXXX1 Shutdown Mode XXXXXXXX0
Write_Max7219(DISPLAY_TEST, 0x00); //Normal Operation XXXXXXX0 Display Test Mode XXXXXXXX1
Write_Max7219(DECODE_MODE, 0xff); //Decode Mode Select D7~D0 1 B decode 0 No decode
Write_Max7219(SCAN_LIMIT, 0x03); //SCAN LIMIT 0~7 0xX0~0xX7
Write_Max7219(INTENSITY, 0x04); //Set Intensity 0xX0~0xXf
uint i,j;
for(i=0;i<x;i++)
for(j=0;j<120;j++);
