Matlab Simulink - Cannot connect to an electrical node
sammy-e
Newbie level 5
Newbie level 5
Hello,
I am having trouble making multiple connections while creating a simple circuit using simulink. I added an AC Voltage Source and two resistors in series. I would like to add a Voltage Measurement in between the resistors, but I cannot create a connection - the dropped wire turns red with a small circle on the end of it. How should this normally be accomplished? Thank you.
Hi, I don' t know if did you solve your problem, but I experienced the same issue..But after 2 hours I got the solution..You have to connect the voltage mesaurement over the electric nodes (the little squares to the left and right of each element). I hope this helps.
Antonio
    sammy-e
Thanks for the info, will definitely give it a try.
