[Matlab] >>(right shift) and <<(left shift)
davyzhu
Advanced Member level 1
oriental
matlab shift
Hi all,
How >>(right shift) and <<(left shift) 2'complement number
(both positive and negative integer).
Is x>>2 equal to floor(x/4)?
And is x<<2 equal to x*4?
Best regards,
Davy
davyzhu
oriental
matlab left shift
Hi hr_rezaee,
Thanks!
The bitshift C = bitshift(A, k) returns the value of A shifted by k bits. Input argument A must be an unsigned integer or an array of unsigned integers.
But I need the signed version.
I used to use floor(x/(2^n)) to emulate x>>n, is it right?
Best regards,
Davy
davyzhu
oriental
matlab shift left
I copy the x >> y definition from a video standard (H.264).
Arithmetic right shift of a two's complement integer representation of x by y binary digits. This function is defined only for positive integer values of y. Bits shifted into the MSBs as a result of the right shift have a value equal to the MSB of x prior to the shift
operation.
Did matlab provide a arithmetic shift function?
Best regards,
Davy
hr_rezaee
Advanced Member level 3
Iran-Mashhad
matlab bit shift
Hi
I don't know but study "Simulink Reference>Shift Arithmetic" and "Simulink Fixed Point>shifts".
they can help you.
regards
farhantariq
Member level 3
Pakistan
matlab shift function
why dont u check MATLAB help for exact answer.u will find brief explanation there
