Jan 18, 2011 #1 M magdi23 Newbie level 4 Joined Jun 2, 2009 Messages 5 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,315 Hello guys i have got an egauation and i need to implement it in matlab in both (simulink and m-file, so could you please help me out. dmM/dt= mM(t)-Rp, the problem here mM(t) which is variable on time, mM max =7.560^-3 when [tm0,tm1]= [30,100 minutes] else mM=0. actually i havent done the if, else programming and i would somebody to help me also with simulink thank you and i am looking forward to hearing from you
Jan 31, 2011 #2 D dheena Newbie level 6 Joined Jan 31, 2011 Messages 13 Helped 3 Reputation 6 Reaction score 3 Trophy points 1,283 Location Erode Activity points 1,338 use the embedded MATLAB function in the simulink for implemnting ur equation or just a function
