A particular DSP system is sampled at 200 kHz, requires a digital Butterworth lowpass filter with a passband ripple of 1 dB at 40 kHz and a minimum stopband attenuation of 22 dB at 60 kHz.
Design the above filter using the impulse invariance method and the bilinear transformation method. Determine the order and the 3 dB cutoff frequency of the analog filter prototype using the formula given in the lecture notes, and then design the analog prototype filter using the M-file buttap of MATLAB. Transform the analog filter transfer function to the desired digital transfer function using the M-files impinvar and bilinear. Plot the magnitude and phase responses of both designs using the M-file fvtool. Compare the performances of the two filters. Show all calculation steps and the MATLAB codes used in the design.
I have this code but i am not sure if this generates what the question requires..can someone help me if this code is wrong?
hi guys
i have this question....who could help me?
design an HPF filter satisfying the following specifications:
|H(ω)| ≤ 0.021 , |ω| ≤ ωs = 0.35π
0.9790 ≤ |H(ω)| ≤ 1.021 , |ω| ≥ ωp = 0.5π
Plot the impulse response. Plot the magnitude, the phase and the group delay.
Verify your design. Try the filter on an audio signal.
