MathCad/Matlab - FM Demodulation!!
disney_snoopy
Newbie level 6
MALAYSIA
fm demodulation
Hi all,
Need your advise on how to write a program for the FM demodulation.
Please do explain here or with an attachment!!!
Thankz.
matlab fm modulation
do you need it using matlab?
matlab fmmod
Yes. Either use MAthCad or Matlab.
I need a Fm demodulation after i modulate my analog signal to FM signal of using FM modulation.
fm demodulation in matlab
My Friend,
If you have matlab installed on your computer you can search with its help, for example see the following:
fmmod
Frequency modulation
Syntax
y = fmmod(x,Fc,Fs,freqdev)
y = fmmod(x,Fc,Fs,freqdev,ini_phase)
Description
y = fmmod(x,Fc,Fs,freqdev) modulates the message signal x using frequency modulation. The carrier signal has frequency Fc (Hz) and sampling rate Fs (Hz), where Fs must be at least 2*Fc. The freqdev argument is the frequency deviation constant (Hz) of the modulated signal.
y = fmmod(x,Fc,Fs,freqdev,ini_phase) specifies the initial phase of the modulated signal, in radians.
Examples
The code below modulates a multichannel signal using fmmod and demodulates it using fmdemod.
Fs = 8000; % Sampling rate of signal
Fc = 3000; % Carrier frequency
t = [0:Fs]'/Fs; % Sampling times
s1 = sin(2*pi*300*t)+2*sin(2*pi*600*t); % Channel 1
s2 = sin(2*pi*150*t)+2*sin(2*pi*900*t); % Channel 2
x = [s1,s2]; % Two-channel signal
dev = 50; % Frequency deviation in modulated signal
y = fmmod(x,Fc,Fs,dev); % Modulate both channels.
z = fmdemod(y,Fc,Fs,dev); % Demodulate both channels.
this is from matlab help.
also you can find the digital mode of all the modulation types.
Regards
fm modulation matlab
Aya2002 said:
My Friend,
fmmod
Syntax
Description
Examples
Regards
Hi aya,
The code that u gv me as example, i paste it in M-files but when run it; it has error on the line 8.
May i know why it has error? Is it i shouldnt paste it in M-files?
Regards,
fm modulation and demodulation in matlab
Hi friend, I checked it, there are no errors with the above program
by the way, this is from matlab help not from me so that it is impossible to have an error.
thanks
matlab commands for fm modulation
Hi please see my mathlab attachment... i print screen the M-file and my command window that show me error.
However, my M-file line 3 does have a []bracket error of red colour line...
matlab programme on frequency modulation
which matlab version are you using?
have you checked which of the input data is of a 'double' type and why?
Added after 2 minutes:
one more thing,
as this is an example straight from the matlab help, go to your matlab help and check what example is given there :) should be something similar, with probably very minor differences :)
mathlab mathcad
im using MathLab R2007b.
So u mean only type help in my command window?
as i type help in my command window and it promt out alot of command but no fm demodulation command.
Please help what command to type in order the example will come out?
Or choose what from the help icon?
Or can you all print screen for me ur source code with the output?
matlab fm source
try help using F1 it should lead you to the help, where you can use for example 'search' option to go to the help about fmmod option, there I can find in my matlab (7.1) exactly the same example that Aya2002 pasted above. Check what do you have there :)
if you are using the help from the command window you can print help fmmod but you won't get the example there, so use F1 option (or choose the question mark from menu ;) ).
good luck
A.
frequency modulation command in matlab
I agree with jamalenka 100% do every thing said by him/her :)
fm modulation m-file
cannot also... it stated no match found!!!
anyhow, can any1 tell me why my source code got error?
Added after 41 minutes:
ok i get the output... Different version is defferent source code.
Anyhow i need to convert it to mathcad but i doesnt know how to convert it to mathcad.
Can anyone help me on this???
All i need to do is write the FM demodulation formula to MathCad.
Thankz
fm demodulation formula
Please HELP!!!
Any formula to do 2 get the demodulated signal as in the mathlab?
All i can found in book and on9 or e-book is talk all bout the demodulation SNR, noise error and etc.
But i need a formula to draw out my graph is the demodulated signal of "frequency versus time"...
Please Help!!!
I would very gratefull if you all would help.
Thankz.
