Material to do soldering on?
Nate25
Newbie level 3
What material should i put on my workbench for soldering? Think carpet would probably burn.
Nate25
Newbie level 3
I will try that. Thanks.
pranam77
Advanced Member level 5
INDIA
Cut required portion of 0.5inch Plywood and lay on the working place which will act as an insulator, which is also harder than ceramic, and will also resist heat to some extent from the molten solder and the Iron. If you work on daily basis, the wood will last for abt 7-8 years. Goodluck
