Apr 8, 2011 #1 Y yasine79 Member level 2 Joined Nov 10, 2009 Messages 49 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Location germany Activity points 1,602 how could convert a .mat file in .s2p file (ADS)? thank you for your help
Apr 8, 2011 #2 V volker_muehlhaus Guest The Touchstone *.s2p file format is simple. Here is the documentation: **broken link removed** The required minimum is the one header line followed by data. You do not need the noise parameter section.
