khanh my
Junior Member level 2
- Joined
- Mar 19, 2013
- Messages
- 23
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,412
Hello,
I' using CCS C example of code for UART communication between one Master and one Slave. It's work well.
However, i'm trying now with two Slaves, One Master and i have problem. 2 slave data transmission on the master was wrong
I do not know how to address the slave, Who has successfully share information
code master
Slave 1:
slave 2:
code master
#include <16f887.h>
#device *=16 ADC=10
#fuses hs,nowdt,noput,noprotect,nobrownout,nolvp,nocpd,nodebug
#use delay(clock=20000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
#include <stdio.h>
#include <lcd_lib_4bit.c>
unsigned int8 doc, value,value2,doc2,a;
void hienthi_lcd (void);
void main()
delay_us(1000);
delay_us(1000);
set_tris_d(0x00);
set_tris_b(0xff);
set_tris_c(0xff);
set_tris_a(0xff);
lcd_init();
delay_ms(500);
while(true)
doc=getchar();
delay_ms(500);
doc2=getchar();
hienthi_lcd ();
void hienthi_lcd (){
lcd_putcmd(line_1);
lcd_putchar("MASTER");
lcd_putcmd(line_2);
printf(lcd_putchar,"H0=%3u H1=%3u",doc,doc2);
Slave 1:
#include <16f887.h>
#device adc=10
#include <stdio.h>
#define station1 0x00
#bit RB0=0x06.0
#bit RB1=0x06.1
#bit RB2=0x06.2
#bit RB3=0x06.3
unsigned int8 doc, value,a;
void doc_xuli_adc(void);
void khoitaouart()
setup_uart(9600);
void main()
delay_us(1000);
set_tris_d(0x00);
set_tris_b(0xff);
set_tris_c(0xff);
set_tris_a(0x01);
setup_adc_ports(san0);
setup_adc(adc_clock_internal);
lcd_init();
delay_ms(500);
khoitaouart();
while(true)
doc_xuli_adc();
putc(doc);
hienthi_lcd ();
void doc_xuli_adc () {
set_adc_channel(0);
delay_us(10);
a=read_adc ();
doc=((float)a*4.88)/10;
void hienthi_lcd () {
lcd_putcmd(line_1);
lcd_putchar("SLAVE1");
lcd_putcmd(line_2);
printf(lcd_putchar,"H1=%3u",doc);
slave 2:
#include <16f887.h>
#device adc=10
#include <stdio.h>
#define station1 0x01
#bit RB0=0x06.0
#bit RB1=0x06.1
#bit RB2=0x06.2
#bit RB3=0x06.3
unsigned int8 doc2, value,a2;
void doc_xuli_adc2(void);
void hienthi_lcd2 (void);
void khoitaouart2()
setup_uart(9600);
void main()
delay_us(1000);
set_tris_d(0x00);
set_tris_b(0xff);
set_tris_c(0xff);
set_tris_a(0x01);
lcd_init();
delay_ms(500);
khoitaouart2();
while(true)
doc_xuli_adc2();
putc(doc2);
hienthi_lcd2 ();
void doc_xuli_adc2 () {
set_adc_channel(0);
delay_us(10);
a2=read_adc ();
doc2=((float)a2*4.88)/10;
void hienthi_lcd2 () {
lcd_putcmd(line_1);
lcd_putcmd(line_2);
printf(lcd_putchar,"H1=%3u",doc2);
