eruisi
Member level 4
I have a filter design in verilog and I want to compile it to Altera Stratix.
In Quartus II, I have an option that can balance mapping to Logic Elements or DSPs. If I choose LEs, no DSP will be used. All calculations are implmented in logics. If I choose DSP, most calculations will be mapped to DSP blocks.
However, I found that the power estimation for DSP implementation is higher than the LE version, which is different from my intuition. I remember that arithmetic operation are preferred to implement in DSP blocks to save interconnection and power but I just get the opposite results.
I use PowerPlay to estimate the power.
