Making delay using Verilog code
EDA_hg81
Advanced Member level 2
delay registers in verilog
Getting data setup errors from source to destination.
I am trying use code as following to realize clock delay.
reg Clock;
reg REG1;
reg REG2;
reg REG3;
reg REG4;
reg REG5;
reg REG6;
reg REG7;
reg REG8;
wire DDR_Clock;
assign DDR_Clock = Clock;
always @ (RAWClock)
begin
REG1 <= RAWClock;
REG2 <= REG1;
REG3 <= REG2;
REG4 <= REG3;
REG5 <= REG4;
REG6 <= REG5;
REG7 <= REG6;
Clock <= REG7;
end
always @ (posedge DDR_Clock)
begin
more code;
end
Do you think I can realize this idea?
Thank you.
sree205
Advanced Member level 1
why don't u just use a 3 bit counter ? it ll infer lesser hardware and still give u the same delay as the idea u have described.
    EDA_hg81
EDA_hg81
Would you like write a sample code for me .
Thank you.:D
sree205
module cnt(rst,raw_clk,ddr_clk);
input raw_clk,rst;
output ddr_clk;
reg ddr_clk;
reg [2] cnt;
always@(posedge raw_clk or negedge rst)
begin
if(!rst)
begin
cnt <= 3'b0;
ddr_clk <= 1'b0;
end
else
begin
cnt <= cnt+1'b1;
if(cnt==3'b111)
ddr_clk <= 1'b1;
else
ddr_clk <= 1'b0;
end
end
endmodule
Added after 1 minutes:
ofcourse, you won't get a 50% dutycycle clock. i'm assuming you are going to use the posedge of clock. this should satisfy ur criteria.
    EDA_hg81
EDA_hg81
Very appreciate for your help!
:D
Added after 58 minutes:
one more quextion.
How can I constrian the new clock, use constrian editor?
Thank you.
kib
Full Member level 1
Bangalore, India
what is ur requirement?
to delay the clock or to divide the clock?
what code sree205 has written is a clock divider
    EDA_hg81
EDA_hg81
I just want to delay the clock for a while.
Do you have any idea?
sree205
looks like i misunderstood the question. if you want a delay the clock by a certain period of time, then the answer for that is shift register and this is the code.
module sht_reg(raw_clk,rst,ddr_clk);
input raw_clk;
input rst;
output ddr_clk;
reg ddr_clk;
reg [7] shift_reg;
begin
if(!rst)
begin
shift_reg <= 8'b0;
ddr_clk <= 1'b0;
end
else
begin
ddr_clk <= shift_reg[0];
shift_reg <= {raw_clk,shift_reg[7]};
end
end
endmodule
ofcourse, instead of 7:0, u can declare a parameter called delay and have [delay] and have the delay configurable one during simulation.
Added after 21 minutes:
to be frank, ur initial idea is also the same, only, i have realized as a bunch of registers and u have done it as individual registers.
    EDA_hg81
EDA_hg81
sree205
Thank you for your help.
sree205
no probs man. here is a checklist document on successful synthesis with constraints.
    EDA_hg81
kib
Full Member level 1
Bangalore, India
i would recommend you to use a dcm for delaying the clock.
above code (shift register approach) may have serious timing problem on an FPGA
sree205
what u r suggesting is to phase shift the clock, if i'm not mistaken. maybe EDA_hg81 can tell how much of delay he wants exactly.
EDA_hg81
I am using spartan 2e, but his guy does not have DCM.
I have to find my way to delay this clock.
your suggestions all are great.
Thank you all and have a good weekend.
sree205
yes, u r right. these r the devices for which DCM is supported.
Virtex-II, Virtex-II Pro, Virtex-II Pro X, Virtex-4, Spartan-3, Spartan-3L devices
Added after 37 seconds:
let me know ur clock frequency and the delay which is needed, let me see if i can come up with a solution.
stockholmicy
Newbie level 1
Newbie level 1
I think you can use ISE core generator RAM-based shift Register to realize it. It's very precise and helpful. You don't need write any code but only need to instantiate it in your design. thank you.
