[SOLVED] main program doesn't get execute if i use RTC interrupt
bikashh
Full Member level 5
india
Dear friends,
thanks for the reply friends,I've solved the problem but still have a small problem with it
->if i enable the RTC interrupt under main() the program works perfectly but when i write it separately under RTCinit() the code after VICIntEnable doesn't work that means rest of the program under mains doesn't execute.
VICVectAddr13 = (unsigned long)RTC_isr;/*Set Interrupt Vector*/
VICVectCntl13 = 15;
VICIntEnable |=(1<<13);
also in the above VICVectCntl13 the actual value to be loaded is 0x2D but doesn't work while it works correctly if i put 15;
please reply
This was true in the 21xx/22xx series where the interrupt needed to be enabled using the 0x20 in the VICVectCntl register.
In 23xx/24xx it doesn't work this way and there is no VICVectCntl register and it is a mistake that Keil includes a define that points VICVectCntl to the VICVectPriority location
the 23xx.h is like this and is wrong
#define VICVectCntl0 (*(volatile unsigned long *)(VIC_BASE_ADDR + 0x200))
#define VICVectCntl1 (*(volatile unsigned long *)(VIC_BASE_ADDR + 0x204))
#define VICVectPriority0 (*(volatile unsigned long *)(VIC_BASE_ADDR + 0x200))
#define VICVectPriority1 (*(volatile unsigned long *)(VIC_BASE_ADDR + 0x204))
The correct code is
Code C - [expand]
VICVectAddr13 = (unsigned long) interrupt_function_name;           /* set interrupt vector 13 */
VICVectPriority13 = 15 ;           /* default priority is 15 (lowest), can be set between 0-15 */
VICIntEnable |= ((unsigned long)1<<13);           /* Enable RTC Interrupt */
Alex
dear friend, I've already used the "VICVectPriority" in my code but the result is still the same.
RTC works correctly but the remaining program under mains doesn't get executed.
Terminal Output:
Real Time Clock = 4 : 4 : 44 : 52 5 5 2011
Real Time Clock = 4 : 4 : 44 : 53 5 5 2011
main()
Init_UART0(9600); // Initilial UART0 = 9600,N,8,1
RTCIN();
while(1) //this loop doesn't get executed.
uart0Puts("hi \n\r");
I tried to debug by writing a sentence after "VICIntEnable |= ((unsigned long)1<<13); "
but that sentence never appear on the terminal except RTC time and date as above.
