Magnetic Flux Density of a single turn rectangular loop
Catalyst
Full Member level 3
magnetic flux rectangular loop
Hi folks,
Does anyone have any links or resources where I can view the formula for calculating the inductance of a single turn rectangular conductor loop and the method for deriving it?
Any advice is appreciated :)
Cat
vfone
Advanced Member level 5
L = 0.394*(r^2)*(N^2) / ( 9*r + 10*length )
where:
L = inductance in uH
r = coil radius in centimetres
N = number of turns
length = length of the coil in centimetres
Catalyst
Full Member level 3
Re: Inductance of a single turn rectangular loop
May i ask where that equation is from?
hrkhari
Full Member level 4
Hi:
You can get the equation of the dc self inductance from Radio Frequency Integrated Circuit Design, by John Rogers and Calvin Plett. Hope this helps
Rgds
Catalyst
Full Member level 3
Thanks for the responses :)
From what I can see, all of those equations are for circular loops, not for rectangular structures.
If I have a conducting loop that is 40cm by 20cm, built with copper tubing (15mm diameter) where do I start when I want to derive a formula for the magnetic flux density B or magnetic field strength H.
These will heavily affect the result of the inductance for the structure surely.
I'm lost :(
Cat
wipower
Newbie level 2
Hi...
this may help you
members.aol.com/marctt2/induct2.pdf
members.aol.com/marctt2/induct1.pdf
from the L you can derive the flux density
