harryzhu
Member level 3
lvs missing port
Hello,Everyone
When I run calibre LVS with chartered's run file, I met such error and all ports in layout can't be recognized. since I cannot find metal1(pn) layer , I labeled the pin name with metal1(dg), but I'm not sure if this is right. Chartered's LVS run file for calibre include three files: *.ctl, *.map, *.lvs, and I paste some usful words here:
In *.ctl:
#DEFINE TEXT_TEXTTYPE_IS_5 // Uncomment this line for TEXT to use the same gdsII number as the conductor
// it attached to, but with a texttype 5, e.g. Artisan Library.
// By default, a texttype 10 is used if the user keep this line commented.
In *.map:
LAYER MAP 14 DATATYPE 0 3014 // Metal1
LAYER MAP 14 DATATYPE 4 2014 // Metal1 Dummy
LAYER MAP 14 DATATYPE 5 914 // Metal1 Blockage
LAYER MAP 14 TEXTTYPE 10 2514 // Metal1 Labels
LAYER M1 3014 2014
LAYER M1_BLK 914
TEXT LAYER 2514
ATTACH 2514 M1_nodev
PORT LAYER TEXT 2510 2545 2514 2516 2520 2519 2507 3017
Through above info I think I should use Metal1 with 'TEXTTYPE=10' as the pin layer, but How to define one layer with TEXTTYPE=10? I try to set one new layer, but I can only set its DATATYPE, how should I do?
BTW, for a layer, is it necessary that 'Stream Layer Number' is equal with its 'Number' item in Attributes?
Thanks for your help!
Hello,Everyone
In *.ctl:
In *.map:
LAYER M1 3014 2014
LAYER M1_BLK 914
TEXT LAYER 2514
