LVS & DRC clearing violations in Encounter
kumar_eee
Advanced Member level 3
Bangalore,India
lvs violations
My PD tool is Encounter. I have ran LVS/DRC using calibre.. now I want to clear those violations reported by calibre.. How to do that?. Is it possible to use Encounter for that or I need to use Virtuoso?.
jitendravlsi
Full Member level 2
Re: LVS & DRC
hi dear,
I didnt get ur question itself.
please make it more clear...
Shurik
Full Member level 3
LVS & DRC
You can't use encounter with calible !!!
The GDSII had unloaded and downloaded in calibre
ljxpjpjljx
Shang Hai
Re: LVS & DRC
Encounter tool should use its format to do LVS & DRC!
sreevyas
India
Re: LVS & DRC
insted v can use Assura and Diva for LVS /DRC, it may be easy and compatible
--sree
kumar_eee
Bangalore,India
Re: LVS & DRC
for cleaning the LVS violations we use virtuoso & export gds file... How do we generate the LEF file for the same GDS file?. If I want to go for the ECO change, then How do I use this GDS as Encounter doesn't import GDS file?.
anil4sat
Newbie level 6
You can load the violation report from calibre in the violation browser and you are able to see the violations.
