sonofflynn
Junior Member level 2
I am getting an LVS error when I use a ndiff resistor in my design. I am using IBM .18um technology and used Generate --> All from Source when creating my layout. The resistor is in the schematic and layout, and both are hooked up to the same nets. However, when looking at the LVS report, it says "missing instance" twice, because the two resistors are not the same name. I'm not sure how this happened..I tried to manually change the name of one of the resistors, but it didn't fix the problem. Any help would be appreciated.
