lvs calibre for new device
cleve
Newbie level 5
Italy
Hi everybody,
I have designed a layout of custom transformer in cadence. I have simulated it in ADS and now I'm trying to do the lvs from layout to nport with s-par. When I run calibre LVS appears an error which say: "Schematic export failed or was cancelled.".
Does anyone know in which way I can do it?
You need to export schematic before you do LVS (that why is its called Layout Versus schematic) . Go to calibre main window , click on file > export > spice (or whatever as per ur need) , then set advanced option in that same pop-up window , click on export.
Check this out , may be it can sort ur problem :
Sorry, but I can understand.
I have a schematic (in cadence) in which I have the nport with s-par file. I have a layout view with the same name (in cadence). Now How could I do the lvs?
p.s I was already using the export from schematic viewer.
