Screamindaemon
Newbie level 3
- Joined
- Oct 14, 2010
- Messages
- 4
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,331
Hello all.
I am building a design using an LVDT to measure distance.
I am using the CD-375-250
I am currently exciting the LVDT by taking a crystal and using a clock divider to bring the frequency to roughly 5 kHz square wave.
I then invert this signal using a standard 7404 series inverter.
I will inject the initial signal into the top of the primary of the LVDT, and the inverted initial signal into the bottom of the primary of the LVDT.
The response from both secondaries is a nice sinusoidal. I then take a peak detect of this sinusoid as changes in amplitude.
However, the response from my secondaries is not a linear amplitude change, and the overall change in amplitude is very small. I also notice that the response from one secondary will phase shift left (as viewed on a scope) a little bit before dropping amplitude, and the other secondary will phase shift to the right a bit before dropping in amplitude.
I have tested this LVDTwithout any extra circuitry and it functions as one would expect and LVDT to function.
Does anybody have any ideas as to why my response from my LVDT when connected to the rest of my system is not the same as it is when it is disconnected from the system?
Thanks for your time.
