LTspice: Modelling a negative resistor
Swend
Full Member level 4
Roskilde, Denmark
Hi friends
For some theoretical LTspice work I need a model for a voltage controlled resistor that can produce both negative and positive resistance.
I thought of making a SUBCKT with a negative impedance converter made up of a single op-amp, but I think that kind of limits it's application. I would like it to be more simple and versatile like the ubiquitous resistor model in LTspice, would that be possible and what approach would most suitable?
You mean modelling a voltage controlled negative resistor in the simulator in contrast to designing a real circuit that exposes a negative resistance?
It can be most easily done with a behavioral current source. I = x*V
Reactions: Swend
    Swend
Yes
Yes I see it now, you mean e.g. like this?
Not specifically, review help for "B. Arbitrary Behavioral Voltage or Current Sources"
Sorry, that's just me assuming you can read my mind. On the left voltage follower with 100ohm load. On the right current source to simulate negative resistance, cancelling out the 100ohm. Obviously some voltage needs to control the current source, so it's just meant as illustrative.
Several years ago I have modelled a voltage-controlled resitor in PSipce using a voltage-controlled current source.
Both output nodes of the source (1,2) were used to specify the VALUE of the current source as a function of the VOLTAGE between both nodes (1,2) divided by a the control voltage.
The direction (sign) of the current defines the resistor between the nodes as positive or negative.
This works for a constant or only time dependent resistor. If the resistance is also a function of another node voltage or branch current, it has to be implemented by a behavioral expression, most simply with a B source.
