Register Log in
LTSpice model of LDO
Adithya_Pai
Newbie level 6
I have set Rds on of LDO using model card
I have obtained 178mOhm Now i have to use in LDO as pass transistor can i directly use this so that Ron will be the same for dropout test case? How should I move forward in developing LDO simple control loop (Pass element, EA , Feedback divider)?
Share some of the exercise if it helps for developing...
KlausST
Super Moderator
Staff member
There are many LDO example circuits in the internet. Some even with explanations and calculations. Choose one.
Do some tests.
If you encounter any problems:
* show us your circuit
* tell us what you expect
* tell us what you see instead
Klaus
Adithya_Pai
Newbie level 6
https://datasheets.maximintegrated.com/en/ds/MAX1725-MAX1726.pdf
Initially I set W, L, Kp value according to Ron required but I didnt obtain dropout voltage required. So I added 9.4 ohm series resistance. Then by trial and error method i set gain of Error amplifier.
Is this proper way of setting ron and Gain of Eroor amplifier. Initially I am expecting loop to work fine with dropout test case , regulated output according to resistor divider set(Steady state)?
Next I will be doing line, load transient which may require some modification...
Toggle Sidebar
Design Fast
