LTI causal system question
emicho
Junior Member level 3
I have a causal LTI system:
h(n) = (a^n)u(n)
and we apply a step function
so by using convolution and little math
we find that
y(n) = [1-a^(n+1)]/[1-a]
my point is :
I read that if I apply a causal input to a causal system that means the output y(n) will be zero for n < 0 ;
but if we substitute some values n<0 in y(n) equation , we didn't that y(n) =0 !!!!
any explanation please !!
Nice question, the impulse response h(n) = 0 for n<0 tells it's a causal system (represented by u(n) in your equation for IR)
for a step input (and the system is at steady state, not excited before this) the system only responds when there is first sample of non zero input signal.
Hence the y(n) = [1-a^(n+1)]/[1-a], is valid for n>0, here the n>0 is one of the condition that "you must" specify as part of y(n), which is missed out in your equation.
It is true that the y(n) equation yields values for n<0. y(n < 0) must be steady state value of h(n) (for input 0), zero in this case.
Reactions: emicho
    emicho
yes, that's make sense..
thank you very much :)
please read n > 0 as n >= 0
Reactions: emicho
    emicho
