MatthewStevenson
Newbie level 2
I've been given the task of modifying a temperature cutoff circuit by employing the use of a 2 stage opamp circuit which consists of a voltage follower, followed by a feedback comparator circuit with hysteresis as attached in figure 1.
The issue is that if I arrange the circuit into a simple voltage follower as per figure 2, I get oscillation at the output of stage 1. If I changed the opamp to either an AD8062 or a TI part, and changed the resistor values accordingly, the oscillation would not present itself.
I simulated it on LTspice and it works as expected. With 2V at the non-inverting input, I get close to 2V at the output with the voltage follower arrangement in figure 2.
We are using this component on another part of the same board with no issues. Can anybody explain why this oscillation occurs and how to prevent it?
Thanks,
Matt
Thanks,
Matt
