Register Log in
LT Spice - Analysis problem : timestep too small
droseman
Junior Member level 3
Hello,
I am attempting to simulate a flyback power supply using LTSpice, I am using coupled inductors to simulate the transformer and a series diode and capacitor across the secondary to remove high voltage spikes.
I am doing a transient analysis .tran 0 100u 0.1u, but when I add the diode on the secondary, I get Analysis: time step too small, and only around 6us of the 100 us span gets simulated. When I remove the diode, I get the whole 100us span.
What could be the issue with this diode which halts the simulation?
NB I can't post netlist or schematic, but it is a fairly conventional flyback converter.
Thanks
Dave
keith1200rs
Super Moderator
Staff member
Yorkshire, UK
I have found LT Spice to be fairly unreliable and seen similar problems. Try adding a small resistor in series with the diode and/or inductors and see if that helps. Make sure you don't have perfect inductors with no resistance - that can cause infinite voltages/currents.
Keith.
droseman
Re: [SOLVED] LT Spice - Analysis problem : timestep too small
I've fixed the issue which was causing my simulation to crash.
I changed the ABSTOL VOLTOL and Gmin values to 2 magnitudes less and I got a successful simulation which was approximately what I was expecting. I suspect that my circuit was on the limit of complexity for finding a solution, as making small changes could make the simulation fail again.
Thanks Keith for your assistance
--dave
Toggle Sidebar
