[ARM] lpc2148 timer pgm is not working
rajslr
Newbie level 1
hi frnds....... here i am posting my code to generate 1s delay using timer 0 in lpc2148.
link to learn 8051
Fosc=12Mhz
CCLK=60Mhz
PCLK=60Mhz
but this code is not generating desired delay :cry:
so correct my code.... thank u :thumbsup:
#include<lpc214x.h>
void timer_init();
void delay(unsigned int a);
void pll();
int main()
IODIR0|=0XFFFFFFFF;			 //port 0 is output
pll();
timer_init();
while(1)
IOSET0|=0xFFFFFFFF;
delay(1000);			 //1s delay
IOCLR0|=0XFFFFFFFF;
unsigned int s;
T0TCR=0X01;				 //enable timer
for(s=0;s<a;s++)
while(T0TC!=T0MR0);		 //wait until tc matches to match reg0
T0TCR=0X00;				 //stop the timer
void pll()				//Fosc=12Mhz,CCLK=60Mhz,PCLK=60MHz
PLL0CON=0x01;
PLL0CFG=0x24;
PLL0FEED=0xaa;
PLL0FEED=0x55;
while(!(PLL0STAT&(1<<10)));
PLL0CON=0x03;
PLL0FEED=0xaa;
PLL0FEED=0x55;
VPBDIV=0x01;
void timer_init()
T0CTCR=0X00;			 //act as a timer
T0PR=0;					 //prescale reg value is 0
T0MR0=59999;			 //match reg0 value is 59999 i.e. { [(60Mhz) * (1 milli sec)]-1 }
T0MCR=0x02;				 //match on reset tc
T0TCR=0X02;				 //reset tc and pc
