Lpc2148 led blink not working.
swami.gangatharan
Junior Member level 3
CHENNAI, INDIA
I build the Led blinking code for LPC 2148. in Evaluation mode i can simulate the code . i can load the code in to the CPU but not working .please any one help me..
Thanks in Advance...
#include <LPC214X.H>
void delay(void);
int main(void)
    IO0DIR |= (1<<22);
    while(1)
            IO0SET |= (1<<22);
 			      delay();
            IO0CLR |= (1<<22); // Turn them off
            delay();			// drive P0.30 High
    return 0; // this wont execute ever :P
void delay(void)
    int z,c;
    c=0;
    for(z=0; z<40000; z++) // You can edit this as per your needs
        c++; // something needs to be here else KEIL compiler will remove the for loop!
