[ARM] lpc2148 code need correction :
balasiva2020
Newbie level 3
Newbie level 3
This is my code(i2c with EEPROM INTERFACE) which is not working. So please help me
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
#include <LPC214X.H>
#define bitset(var,bitno) ((var)|=1<<(bitno))
#define bitclr(var,bitno) ((var)&=~(1<<(bitno)))
// Timer.h for lpc2148
    #define PLOCK 0x00000400
    #define PRESCALE 60000
    typedef unsigned long int int32;
    typedef unsigned char int8;
    void set_clock(void);
    void timer_init(void);
    void delay_ms(int32);
void I2C_START();
void I2C_WRITE(int8 data);
void I2C_STOP();
void i2c_init(void);
void delay(int);
void lcd_ini();
void lcdcmd(char);
void lcddat(char);
int main()
char temp;
set_clock();
PINSEL0=0X00000050;
PINSEL1=0X00000000;
IODIR0=0XFFFFFFF0;
IOCLR0=0xFFFFFFFF;
lcd_ini();
i2c_init();
while(1)
I2C_START();
I2C_WRITE(0xA0);
I2C_WRITE(0);
I2C_WRITE('K');
I2C_STOP();
delay(1000);
I2C_START();
I2C_WRITE(0xA0);
I2C_WRITE(0);
I2C_START();
I2C_WRITE(0xA1);
temp=(I2C0DAT);
lcddat(temp);
I2C_STOP();
void I2C_START()
I2C0CONCLR=0x08;
I2C0CONSET=0x20;
while(!(I2C0STAT&0x08));
I2C0CONCLR=0x20;
I2C0DAT=data;
I2C0CONCLR=0x08;
while(!(I2C0STAT&0x18));
void I2C_STOP()
I2C0CONCLR=0x00;
I2C0CONSET=0x14;
while(!(I2C0STAT&0xA0));
void i2c_init()
I2C0CONCLR=0XFF;
I2C0CONSET=0X44;   // CLEAR ALL FLAGS
I2C0CONSET  = 0x20; //Enable the I2C interface
I2C0SCLH=0x0C;       // Clock High 147
I2C0SCLL=0x0D;       // CLOCK Low 147
 void lcd_ini()
lcdcmd(0x38);
lcdcmd(0x0e);
lcdcmd(0x06);
lcdcmd(0x01);
lcdcmd(0x80);
 void lcdcmd(char dat)
IOCLR0|=0XFF<<16;
bitclr(IOPIN0,10); //RS=0
bitset(IOPIN0,13); // EN=1
IOPIN0|=dat<<16;
delay(1000);
bitclr(IOPIN0,13); //EN=0
 void lcddat(char dat)
IOCLR0|=0XFF<<16;
bitset(IOPIN0,10); //RS=1
IOPIN0|=dat<<16;
delay(1000);
void delay(int y)
int r,t;
for(r=0;r<y;r++)
for(t=0;t<60;t++);
    PLL0CON = 0x01;
    PLL0CFG = 0x24;         // PCLK = (5*Fosc) => 60MHz
    PLL0FEED = 0xAA;        // Feed sequence to enable the Control & config data
    PLL0FEED = 0x55;
    while( !(PLL0STAT & PLOCK ));
    PLL0CON = 0x03;
    PLL0FEED = 0x55;
    VPBDIV = 0x01;          // Assigning PCLK = CCLK
