xpress_embedo
Hello!! i am using LPC2138 to do some experiment with ARM.
Started with LPC2138 Because it is available in Proteus.
Had write the codes for LCD, UART and LED Blinking but the problem i am facing with ADC is that, it working well in Keil Simulator.
But when simulating it in Proteus, is creating a problem.
Like when i connect POT-HG with P0.27 i.e A0.0 of LPC2138, my lcd doesn't show anything and an error appears in the Proteus Simulation Window.
But when i disconnect the POT-HG data on LCD Appears properly, why it is so. this is really weird behavior by Proteus.
Please help me if i am doing some thing wrong.
The code is as follow:-
I had not posted the full code but the modules are posted and i think which are sufficient.
Most Important thing i noticed, there is some problem with Enable Pin of LCD, it is not showing led dot in-spite of that it is showing grey mark when pot-hg is connected, otherwise it is okay.
Enable pin is associated with Analog to Digital Converter 0
Please help me
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 /*****************ADC Functions***************/ void ADC0_Init(void) { /*************Initialize ADC AD0.0*************/ AD0CR = 1<<21; //A/D is Operational AD0CR = 0<<21; //A/D is in Power Down Mode PCONP = (PCONP &0x001817BE) | (1UL<<12); PINSEL0 = 0x00; PINSEL1 = 0x00400000; //P0.27 is Configured as Analog to Digital Converter Pin AD0.0 AD0CR = 0x00200401; //CLKDIV=4,Channel-0.0 Selected,A/D is Operational /* A/D Clock = PCLK /(CLKDIV+1); */ /**********************************************/ } unsigned int ADC0_Read(void) { unsigned long adc_data; AD0CR |= 1UL<<24; //Start Conversion do { adc_data = AD0GDR; }while(!(adc_data & 0x80000000)); //Wait untill the DONE bits Sets AD0CR &= ~0x01000000; //Stops the A/D Conversion adc_data = adc_data >> 6; adc_data = adc_data & 0x3FF; //Clearing all other Bits return (adc_data); } /*********************************************/ unsigned long adc_data; int main() { unsigned char msg[] = "EMBEDDED LAB"; unsigned char adc_example[] = "ADC EXAMPLE"; unsigned char data_received[] = "ADC VALUE:"; Lcd_Init(); UART0_Init(); Delay_ms(10); UART0_Write_Text(msg); UART0_Write(10); UART0_Write(13); Lcd_Write_Text(msg); Lcd_Cmd(SECOND_ROW); Lcd_Write_Text(adc_example); UART0_Write_Text(adc_example); UART0_Write(10); UART0_Write(13); Delay_ms(1000); Lcd_Cmd(LCD_CLEAR); Lcd_Write_Text(data_received); Lcd_Cmd(SECOND_ROW); ADC0_Init(); while(1) { adc_data = ADC0_Read(); adc_data = adc_data*3300; adc_data = adc_data/1023; //Value of Voltage in Milli Volts Display_Number_Lcd(2,1,4,adc_data); Lcd_Write('m'); Lcd_Write('V'); Delay_ms(10); } }
Please help me
