LPC2114 problem with kit handelling
amitdpg
Newbie level 5
Newbie level 5
Reply with quote Edit/Delete this post Delete this post
Report this post to the moderators of this forum
hi
i am using ARM LPC2100 board of zlgmcu I will not able to execute the code for ADC and uart ADC i/p is connected to pin P0.28 and P0.27
I am using Cygwin as a compiler
Did you know any free software
I have a JTAG but i dont know , how to used with the board , for that does required any software
Do you know any free RTOS
pls reply
Hi
Goin the LPC group on Yahoo site read the list note and ask question regarding ARM
But first befor jumping right into rtos blink the LED on your board
You can download a kikstart software from IAR or KEIL site
All the best
Bobi
can you pls tell me you are not able to execute means what and if possible tell me steps are you following in programming .
In GNU toolchain you need to configure lot of the things PLL, MAM,Stacks for various modes , finally you should work in User mode.
Keil does all these things for you ...in its startup routine and it has very good peripheral simulator for LPC21xx you heck this using keil..
Eval version of keil for ARM is having 16K code limitation but code you are mensioning will be much smaller than it.
So use keil eval version. generate hex file .download it using LPC Flash ISP utility
and check it ..After this you can try it over GNU tool with doing all the configurations.
