LPC1788 with SSD memory
panneerrajan
Member level 1
Member level 1
Trivandrum
We need to interface SSD memory with LPC1788 (NXP-ARM7) controller, May i know the possibility of this? If possible kindly let me know the procedure.
Which SSD memory interface do you consider? If you think of SATA interfaced SSD, you need at least an IDE-to SATA bridge. IDE is essentially a 16-bit parallel port with some control lines and can be easily implemented on a µP.
