LPC1788 + FreeRtos or RTX + bootlader + Ethernet
yanvaslij
Newbie level 3
Newbie level 3
[ARM] LPC1788 + FreeRtos or RTX + bootlader + Ethernet
Hi all,
I have try to develop an ethernet bootloader via tftp. First program (bootloader is placed in 0x0000-0xFFFF adress area) gets bin file from tftp-server and flashes it to from 0x10000 to the end of IROM. After all it jumps using this:
__asm void boot_jump( uint32_t address )
  LDR SP, [R0]            ;Load new stack pointer address
  LDR PC, [R0, #4]      ;Load new program counter address
 * @brief Jump to second program
 * @param address
void jumpToProgram (uint32_t address)
        SCB->VTOR = address & 0x3FFFFF80;
        boot_jump(address);
//some code here
        // jumping to second program from bootloader
        else if(memcmp("jump\r", str, strlen("jump\r")) ==0 )
            vTaskEndScheduler();
            jumpToProgram(0x10000);
//some code here
Second program is shifted to 0x10000 by compiler (IROM1 start parametr is 0x10000). It works if I don't use any RTOS in second program. If I do, then program crashes at starting sheduler (vTaskStartScheduler() in FreeRtos or os_sys_init() in RTX). Furthermore I figured out that if I exclude frome bootloader file EMAC_LPC177x_8x.c the second program starts working (sheduler starts) after jumping in it from bootloader. What is wrong?
Regards Vasilij
Problem solved! I call SystemInit in second program. It reinitialize VTOR to 0x0000 value:
void SystemInit (void)
//some code
#ifdef  __RAM_MODE__
  SCB->VTOR  = 0x10000000 & 0x3FFFFF80;
#else
  SCB->VTOR  = 0x00000000 & 0x3FFFFF80;
#endif
So I should to remap vectors in second program after systemInit or shouldn't call systemInit in second program.
