doragasu
Newbie level 3
I want to build a RF transsmitter and receiver. The transmitter only have to tx a carrier signal of a known frequency, and the receiver has only to detect the carrier signal at that frequency. There is no data transmission/signal modulation. Only carrier tx/rx.
I want to embed the receiver inside a key ring, so it must be really small (including the antenna) and power consumption must be really low. I want to power the receiver with 2~3 button cells. Due to the small size, I suppose frequency must be high (hundreds of MHz or higher) to be able to use a small aerial.
At first I thought about using a CC430 for the receiver, because I have a eZ430 Chronos I can use to transmit, but I think this is overkill, and also power consumption is high (15 mA for receiving).
I suppose there must be a better solution maybe using discrete components. Any help about this?
