[SOLVED] Low Voltage Low Power gm/id design method.
skoda
Junior Member level 3
I try to design symmetrics ota ( Sansen page 216 ), I use gm/id methodology ( i have learn it from D.M. Binkley tradeoffs), so a use this equation :
W/L= (1/IC) * (Idrain/Io) but when i need to design transistor Nmos for 25nA and IC=10, a will get W/L=1/256 which introduce me into problem with min. lenght which i have calculated by: Lmin= Wmin*L/W = 102.4u. Anyway cadence return me error because i have wrong Lmin or Lmax or Wmin Wmax.
(Io i mean technological current for 0.18um)
So is this methodology still propper for such low current? Please help to small student from Czech Republic :cry: .
thank you dominik, and how can I do it ? I know that in property a can wrtie NM0<1:10> but i think this is parallel combination, and I dont want stack 8-10 transistor over full editor windows, there must be some trick for that, isn't it?
Using vector You are able to make serial connection, i.e. for instance M1<9:0> net from drain side should be labeled "net1,n<9:1>" while from source "n<8:0>,net2", where net1 is drain connection to other instance and net2 is source cennection to other instances (or supply/ground).
And rememeber to short all bulks of transistor together.
Reactions: skoda
    skoda
thank you guys! still i have problem with an extra cell ( I take a picutre of this extra cell). Anyway I need transistor with IC=10, Id=25nA NMOS, then I use Binkley equation W/L= (1/IC) * (Idrain/Io) and I get W/L=1/256, and if the Wmin=0.4u then the Lmin=102.4u. So I choose 8 transistor in seriies everyone gets AR=1/256 an L=13u (13*8=104u), but there is a problem that is same problem with lmin-lmax, so should I somehow devide AR=W/L=1/256 to this 8 transistor? 8serial.png
... L=13u (13*8=104u), but there is a problem that is same problem with lmin-lmax, so should I somehow devide AR=W/L=1/256 to this 8 transistor?
If your sim-model allows (e.g.) Lmax=10µm, use a cell stack size of > 104/10 , i.e. 11 series transistors of L=104/11 .
Or use Dominik's method with one transistor array Mxy<11:1> and his suggested connection method by appropriate node naming.
Reactions: skoda
    skoda
Hi erikl,
I got your idea, but problem is that cadence still write error. In atteched picture,I tri to set W/L=1/128 because I need Id=50nA and IC=10, Lmin is 52um, so I do 3 series mosfet each L=20um. But cadence still see that each transistor has W/L=1/128 and L=20um and that is the point of problem, he judge it as single transistor and write Screenshot from 2014-08-11 21:02:18.pngScreenshot from 2014-08-11 21:02:32.pngerror. As you can see I try to make a Cellview but it doesnt help.
w=20um/128=156.25nm its probably too small value for your technology. Set the minimum width for your transistor (it should be around 250nm, but You should check in process manual) and set proper length.
Reactions: skoda
    skoda
... so I do 3 series mosfet each L=20um.
If you have 3 MOSFETs with length=20µm in series (Ltot=60µm), you can use a width w=(1/128)*60µm = 0.47µm , which should be allowed in a 0.18µ process. This gives you a W/L = 1/128 .
Reactions: skoda
    skoda
Sorry guys Im just newbie and bad student :D I got the point and my problem is soved, thanks for your patience :)
