dat209
Newbie level 3
I am working with a single board computer that has a strange power supply issue. After trying some work-arounds, I've found a way to fix it, which requires me to dump all the capacitors if the voltage goes beneath a certain threshold in order for the computer to turn on again. I'm trying to design a circuit that can do this automatically.
I need a circuit that will normally operate by forwarding a voltage (22V) to the computer. If this voltage decreases below a threshold (still TBD, but around 7V), I need this circuit to dump everything to a low value load resistor to drain the capacitors fully.
I've been trying to mess around with FETs for this, but all my simulations and math can't give me a solution to this.
I basically just need a circuit that acts as a normally closed switch, but when higher voltages are applied, opens. I'd like to avoid using a relay if at all possible.
Thanks!
Thanks!
