ali2002
Hello I am facing a problem regarding design of passive LPF.I have already found the order of the filter that comes out to be n=4.For this order the C AND L values were calculated and praticaly filter was designed and tested.
During the testing stage it was found that after the implementation of passive filters on the circuit the voltage onthe circuit on which it was implemented boosted up above 25% of previosly observed value.
Ithink so resonace is happening and there is a continous unstable swing of wavefrom at the output from 1 top 25% above the refrence volatge value.Now i want to know why this resonance/ringing is happening and what is the solution for this problem in order to bring stability in design .
Secondly i want to know what should be the range of resonace frequeny whether it should be set within the fps and fsb frequency or if there is any relationship between fps &fsb frequency and resonance frequency.
Waiting for your kind reply
