arefeidi
Member level 4
I've got a big problem: I'd like to connect a DSP-board (input impedance 120 Ohms) to the output of a lowpass-filter (output impedance 4.7 kOhm).
So, to not load the source in such a heavy way I need to build a voltage follower with a low output impedance. Though, I only have some u741 and TL071 OP Amps which (as I think) have to much output impedance.
Does anyone of you have an idea which OP Amp with low ouptut impedance (should be well below 30 Ohms I'd say) I could use or does anyone have another idea how to solve the problem?
thanks alot for any answer!
