Low COST Xilinx FPGA evaluation boards somewhere??
incognito
Member level 2
Member level 2
burched fpga 300
Problem is always we don't find correct packages..., seem always the chip package is the smallest available ie Spartan II XC100 with a PQ208 package, this reduce the user IO blocks available count dramatically
it's easy to find AVNET boards, or INSIGHT boards. BUt it might be possible to find some more little companies who are targetting low cost education stuff like boards.
Any help appreciated
With regards
moZfet,
I don't really know the price range you had in mind, but a friend of mine just purchased on the these. He had a few good things to say about it.
Although it is contrained to 208 pins, it is a spartan 2e 300, Just a little bigger than the 100.
hxxp://w*w.burched.com.au/
Hope this helps a little.
robotman
It's interesting.
Thanks.
robotman said:
moZfet,
robotman
sadelly it's PQ208, for exemple if u try to place & route the oregano systems 8051 core, u will get an error while starting place & route
this is because this oregano core might require 155 ext io blocks ( that I still find wierd ) url. h**p://www.oregano.at/services/mc8051/mc8051_design.zip:
Spartan-IIE User I/O Chart
XC2S300E:
max I/O = 329
pq208 I/O = 146
ft256 I/O = 182
fg456 I/O = 329
as u can see for same device samellest package reduce for the half available IO blocks
But the board url u sent is just so nice, unfortunately it's not ft256 or fg456
With Regards,
moZfet
Hi mozfet!
Oregano's design needs so many I/O's because they have separated the busses. I think there are seperate busses for XDATA and CODE. And the I/O ports are not bidirectional. Every 8bit port consists of 16 lines, 8 for input and 8 for ouput. I had the same problem while fitting their 8051 to XC2S200 with PQ208! Theses busses are designed to connect to FPGA internal peripherals. You don't need to lead all of them to external pins.
regards
The General
GeneralMadDog said:
Hi mozfet!
regards
The General
ya even worse, I know now that this core is orignally designed for be a block in a SoC design
Regards :)
