low cost PCB manufacturing in Egypt
yahiatnt
Dear all,
I am interested in making embedded systems from design to pcb, when it comes to pcb I know a guy who makes it for me but COST is an issue.
I want to know pcb factories, stores, or even freelancers here in Egypt, Cairo, or near Cairo capable of producing at most A4 size single-side and double-side.
Note: Put in mind that I want low cost for prototyping not mass production.
If you can give me the address and contact info I would be thankful.
Sincerely :D
Any reason you don't want to make them yourself - thats the cheapest way for prototype boards.
A simple UV box and presensitied board with the output from a laser printer can give excellent results, with minimum effort.
See this thread and the PDF near the bottom on page 1 on how to make a simple cheap UV Led box.
If you want solder resist coatings and things like smd masks then diy is a lost cause - you have to use the big guys.
Also worth enquiring with overseas board makers as some do offer competative rates.
you can go to NTI (elma3had elqaomi lel-etisalat) in nasr city, the PCB may cost from 100 LE and up, or you can find free lancers in bab el-loq.
if you find someone else please inform me too.
good luck
Hi ;
I'm in Egypt i can make basic & moderate complexity PCB :
i.e: prototypes , PCB layout , soldering ,troubleshooting ......etc.
cell no. : 0108541659
