Serg_SV
Member level 3
load values in PSD15.1
Hello everyboby?
When I create component in Part Developer, I assert type for pin. Load column has two fields, Low and High. The values of output Low and
High fields determine the low and high output load values for the pin in mA. Why high output load values for the pin has negative value?
I think it's dont correct. Analogue situation with type BIDIR.
Thank you.
Regards Serg.
Hello everyboby?
Thank you.
Regards Serg.
