Loud speaker driver.
priestnot
Member level 5
Member level 5
Hello I have to drive a speaker / piezo to play a siren tone as laud as possible.
But I am running into some problems.
The first one is that I have a piezo and for it to be lowder I have to apply to it a square wave with at least 24Vpp.
The thing is I am making the square wave using a NE555 and I have a power source of 12Vdc.
Is there a cheap way to make the square wave to be generated with -12V to 12V or 0 to 24V?
You can run your circuit from 24V and use a regulator for the 555. On the output, you can have a driver stage to give you output swing between 0-24V. The circuit below shows the general idea.
The circuit must run with a 12V source. Its a requisite.
Ok, then you can do something like this below. You connect the transducer (between VF3/4) so that both ends can swing between 0 and 12V but 180° out of phase. Instead of keeping one end tied to 0V, both ends can swing, thus effectively giving a delta swing of ≈24V.
I cannot see any circuit...
